Displays the ethertype information and secondary ethertype port_ list for VLANs, VMANs and PBBNs
N/A.
None.
The following example shows the command output on switches that support only VMANs:
vMan ethertype: 0x88a8
The following example shows the command output on switches that support PBBNs:
# show vman ethertype vman ethertype : 0x88a8 bvlan ethertype: 0x88b5
The following example shows the command output when a secondary ethertype is configured with ports information:
# show vman ethertype Vman Primary ethertype : 0x9100 Vman Secondary ethertype : 0x8100 BVlan ethertype : 0x88b5 Secondary ethertype ports : 6:2g 6:3
The letter g in the port list indicates that the port is a LAG/Trunk port, the details of which can be seen using the show port sharing command.
This command was first available in ExtremeXOS 11.0.
Information on IEE 802.1ah was added in ExtremeXOS 11.4.
